LIAN LI PC-Q10 - Thoughts?
well, its 152% the size of the M1, but it does look pretty snazzy, especially for the price. Is it brand new?
If you need the M1 for watercooling, don't get the PC-Q10, you'd have to mount radiators externally.
But if you're planning to use a tower-cooler anyway and only want an ATX PSU and are on a budget or desperately want a window, this is the better option.
I just saw this case put on on Newegg. Anyone have any thoughts on it? I was thinking of going with the NCase M1 but this looks pretty comparable in terms of size and what you get and it's also $100 cheaper.
You should look at the Cougar QBX which is very similar and half the price.
I got impatient and just got this case and finished the build today. I had to remove the front IO/USB 3.0+ Audo to fit a 10.91 inch GTX Gigabyte 970 Extreme. It says it can fit 10.5 card but if you dont remove the front the dam USB is so thick its nearly impossible to get in. That being said, It looks amazing, I can take pics later if u want. the Xtreme 970 looks badass too
and by the way once you remove the front USB and Audio, it could prob fit a 12 inch+ card. I used Silverstone Strider 650 platinum 140mm for PSU also
