So I am putting together a PC-q07 system as soon as newegg ships all the parts.. This shall be my 2nd SFF build & my 1st for me.. This is going to be an all around system leaning towards mid level gaming.
Parts List:
Case - Lian Li PC-Q07
Motherboard - Zotax G43ITX-A-E
CPU - Core 2 Duo e6600 65w
CPU Cooler - Scythe Big Shuriken SCBSK-1000 120mm
Memory - OCZ Platinum 4GB (2 x 2GB) DDR2 1066
Hard Drive - 80gb Intel x18-m (sold on newegg as Dane Elec)
Power Supply - CORSAIR CMPSU-400CX 400W
VGA - ASUS EAH5750 FORMULA (Radeon HD 5750)
This will be a pretty straight forward build, But due to the hardware used I will go ahead & keep a picture log..
The one Modification that I know is going to get done is going to be to the PSU.. I already had a corsair hx520 that I Was going to use & I had actually ordered the 400cx for my server.. But due to the extreme tight quarters & the VERY generous cable lengths that corsair gives on all there PSU's I Decided that they needed shortened.. Well since this system should never exceed the 400cx's capabilities I Figured I would tailor the cables to fit. This is going to be done in a fairly high end manner by re soldering the cables directly inside the unit, but only leaving the cables each about 10-12" long.
I am way excited about this build as I am currently Using a FULL tower Lian Li (rocketfish) that is just way way way too big. & I want to be able to put my computer back on my desk again.
I Debated waiting for the pc-q08, but in the end decided that although I would have liked a little more room for the graphics I Really didn't want the extra depth. The PC-q07 was the most compact that I figured I could realistically build a system into taking into account that the depth was a bigger factor then the height as this will be sitting next to my monitor.
The prime challenges I see with this will simply be the clean routing& Getting my Big Ass Hands in there to do anything.
The only possible future upgrade I can see is a 2nd matching drive for a raid 0 setup if I run out of space on that 80 very quickly. However I have a home server that will be at 4tb of storage after I get the newest drive for it so nothing gets archived or saved locally on my system.
Any pre-build comments about this case would be appreciated.
Pics to Follow as soon as everything gets here.
Parts List:
