Lian Li PC-P60
Papagaj
Hello everyone. At the end of this month I'm planning to build a new rig.... preprations for Age of Conan: Hyborian Adventures :)
It will consists of this:
CPU: C2D E8500
CPU cooler: Noctua NH-U12P
VGA: Nvidia 9800GX2 OC version
MB: GB X38-DS4
RAM: Kingston HyperX 4 x 1GB 1150 MHz
Audio: Creative SB X-Fi mX Xtreme Gamer - Fatality Pro Edition
Case: Lian Li PC-P60 ArmorSuit - Black
Power: ENERMAX Infinity 650W
But my problem is...will i fit that power supply in? Does anyone have this case? I've read somewhere that one guy put a power supply with 150*86*190 dimensions inside but he had difficult times because the upper 140mm fan stands on the way of that power supply. Enermax Infiniti has 150*86*160...3cm shorter so I'm just hoping it will be ok... what do you think guys?
Also I hope Noctua NH-U12P will fit in... I tried to google but all i found is 1....yes just one review about Lian Li PC-P60 :(
So does anyone own one guys? Sry for my bad English btw.
i DONT HAVE THIS CASE,BUT I THINK THE POWER SUPPLY SHOULD FIT WITH NO PROB..oops
