mussafry89
- Jun 6, 2008
i Find this case sooooooooooooooooooooooooo sexy! but i have a few questions. (Since the A77 is also the same case, just without the front panel)
Firstly, is it possible to make the PSU on the top and make the bottom just a vent? I dont know why, but i find having the PSU on the bottom is pretty stupid because of wire management. Wouldnt it be so much easier taking the wires to the back of the mobo from the top?
The front panel, is kinda flawed. Like the vents that are used in the front, for the two front fans only cover the space of 1 fan. The top fan is just blocked by the front panel, so i wonder how effective that fan is gonna be.
Also, im wondering. How easy (or hard) is it to remove the top part of the case? Is it just thumbscrews?
Because im only having one DVD Drive theres so much wasted space, which is why im thinking of getting the A77 because i can add more fans at the front (but i find any case without a front panel so plain and ugly) which is also why i am thinking of the PC-80 Armorsuit. I Emailed LianLi asked about the Armorsuit. I asked whether i could put a A-77 Top Case cover, instead of the normal one on the Armorsuit, that way i can install a triple rad on the top easily.
Does any1 have any pictures of the A77 case? Or a worklog or something. Same goes with the PC-80.
