Lian Li PC-A70
fantomau
Got my Lian Li PC-A70 the other day and WOW is it ALOT bigger than my armor.
I also got a W-75 side panel w/ window and it looks great.
I havent put the system together yet, But have found a couple of annoyances so far in the case.
The power button sometimes sticks in when you press it and you have to touch it slightly for it to pop back out. (I took the switch housing off and found out that the reset switch has a rubber gasket around it, But the power switch doesnt, Which may be the cause of the button sticking in).
I tried to put in my bulgin power switch, And it fit fine in the panel and looked great, But on the case, Theres a circuit board w/ 2 push buttons for the power and reset and removing the stock power switch, Left the reset switch off. If anyone knows of a way to replace the stock power w/ a vandal switch, And still retain the reset switch, I'd like to hear how.
Was a PITA to mount 5.25 devices like a Scythe Kama Bay and Zalman Fan contoller and get them to align evenly.
The case is stunning visualy and massive and cant wait to build my system.
I wish the optional top panel w/ two 120mm fans was available.
Does that W-75 side panel actually fit?
I've had this case for a while, but I've been waiting on parts to come in stock before I do my build in it. It is very nice looking, and as you said, much roomier than my old armor.
Just ordered a canon digicam, So when I get it, I'm gonna go wild w/ pics ;)
