I'd been reading a couple reviews on this case, and I'd have to say, this is by far one of the most appealing cases that I've seen in a while. I do have a question, if anyone would mind taking a stab at.
It allows for dual power supplies, using that y adapter to signal the secondary power supply to turn on when the power is switched on. However, my concern is, say I divy up the components, where the Video cards are powered by the secondary power supply. What would happen if either fail.
Main Fails: Does the secondary stay on, keeping power to the video cards (bad in my book)
Secondary Fails: The video cards lose power, but the mobo and cpu still run (may cause a reboot, still bad)
I guess what I'm trying to figure out here is if one fails, or shuts off, is there some type of fail safe that will turn both off given the use of that adapter. If I'm overthinking or overworrying, I apologize.
