Highcountryrider
- Aug 7, 2009
Noobie here,1st post. About to build a system (my second build, 1st was for a friend). I really like the Lian A05 NB case, mainly for it's size but also for Lian's quality. I'm looking for opinions about whether I will have any problems with the components I plan on using fitting properly. Main concerns are the video card and the CPU cooler. Also, I have read some issues about the air pockets in this case and wonder whether the components listed will produce any excessive heat problems.
Here is a quick composite of the case interior and the Gigabyte MB I plan on using. Will the PCI Express video card fit without interfering with the 3.5 floppy/external 5.25 bays? Also, will the Zalman CPU cooler listed below fit OK?
Here are the components I plan on installing:
GIGABYTE GA-EP45-UD3R LGA 775 MB
Intel Core 2 Duo E8400 Wolfdale 3.0GHz Dual-Core Processor
2 x Western Digital Caviar Black WD5001AALS 500GB HDD configured RAID1
EVGA GeForce 9600 GT 512MB 256-bit GDDR3 PCI Video Card
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) RAM
ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
Antec EarthWatts EA650 650W Power Supply
Sony Optiarc Black 24X DVD+R SATA DVD Burner
Main uses will be for graphics production and moderate video editing. No gaming - well maybe MS Flight Simulator.
TIA for any replies and suggestions.
