I'm leaning towards this case for my next build: http://www.lian-li.com.tw/v2/en/product/product06.php?pr_index=221&cl_index=1&sc_index=25&ss_index=62
I was wondering if the existing windowed side panels will also be compatible with this model (leaning towards the 65P or the new 65M): http://www.lian-li.com.tw/v2/en/product/product04.php?cl_index=2&sc_index=29&ss_index=72
I assume they should work as it appears the dimensions are identical to the PC-7 model, but i figured I would ask to see if anyone knew for sure. Also, i was considering tossing in one of the PCI cooling kits (either the BS-02 or 03), but was not sure how effective they would be if at all. http://www.lian-li.com.tw/v2/en/product/product04.php?cl_index=2&sc_index=34&ss_index=83
Any comments or input would be greatly appreciated.
Thanks,
JD
Thanks,
JD
