Lian-Li PC-7B Plus II
vage
I was wondering if anyone has done water cooling in this case? I want to water-cool my rig but I never have before and I have a feeling like this would require some modification to the case, so I was hoping someone had some guidelines I could go follow.
You can fit a 120.2 radiator in the top by cutting a hole and using a grill.
ok so what is 120.2 compared to 120.1? Does that just mean that the radiator is the size of 2 120 fans? Does it interfere with the Optical drive at all if I use that?
Yes- 120.2 means 2 120mm fans. It will likely interfere with the DVD drive, but if you put your drive in any of the bays from 2-4 you should be ok. When I had a PC-7, I had a 120.2 up top and the 4th bay was for my DVD drive. Worked great.
