Lian li Pc-7 plus specs
I'll trade and give you $10 USD if you buy the one you want and I give you this:
and you give me that :)
lol nah ah i feel like buying new any way why do lian li use 2 different specs with the same name???
From what I can find theres 2 differant cases, theres the "PC-7 Plus" and a "PC-7 Plus II". the Plus II has the 120mm Rear Fan where as the Plus 7 has a 80mm rear fan.
Mine is new, about a month or so. One small scratch on the side panel, barely visible.
no, I have a PC-7 Plusand it uses a 120mm exhaust fan
however, the PC-65 Plus uses a 80mm exhaust fan because of the removable motherboard tray
there was initial confusion about this last year
http://hardforum.com/showthread.php?t=865773
kk all cool i brought the pc-7 plus case form a shop and i got the 2 120mm fans version ty
Adidas4275 said:
i have some rev of the PC-7 with an 80mm rear fan and no mobo tray
so there is indeed 2 versions?
interesting
can you take some pics?
Make sure you get the Lian Li PC7 Plus II. That case has 2x120mm fans and an 80mm top blowhole.
