Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey everyone, I'm looking to drill/cut a hole into the top of my case near the PSU (to route the cables from the back) and was wondering what is the most preferable tool to use? (I've never done any kind of case moding before)
I used a drill to drill small holes into an outline of the big wiring hole, then I used a dremel w/ cutting disk to connect the dots. After that, all that remains is to file down the jagged/sharp edges. This mod seems almost necessary for a clean wiring job in Lian-Li's.
