Lian-Li Pc-65B Question
80mm fans. i believe it's listed everywhere. :)
but you're only cool if you do the 120mm intake fan mod. ;)
I'd like to do this mod
got any worklogs or links?
ThirtySixBelow said:
It uses 4 80mm fans. But, I am so uncool that I don't know about the 120mm fan mod.
friend and i did it, basically just involves making the 2-80mm fan intake into 1 120mm i'll post pics when i find em
edit, until i do find them, my friend and i found that for us personally, it helped lower the temps, and noise levels vs. the 2 80mm fan intakes. those that do have pc61's however, take off the front bezel and just take a cd disc and place it on the front near the fans, you'll see that it's easy to fit on there with enough clearence for everything to fit.
so, one 120mm fan worked better than 2 80mm fans?
hi.
I'm about to have a go at fitting a 120mm fan in the front of my lian li.
Has anyone managed to fit one in the back? It looks almost possible.
lemons said:
hi.
I don't think it would be possible to fit one on the back without some serious modding. Your best bet would be to put 2 really quiet 80mm fans back there.
