Hey guys.
Right now I have stock fans on my Lian-Li PC-65.
I'm planning on getting new fans to replace the stock, but I want to acheive the base Air Flow I can get using 80mm and 120mm fans, to get nice cooling.
Now I know it's "easy" to get a 120mm fan on top, but what about the front. The front 2 fans are the only intakes I have. Here's a few questions I have:
1.) Am I better with a 120mm, or two 80mm with 34+CFM?
2.) Also, for the best air balance, should I have more intakes than exhausts? More exhausts? Or an even number of intakes and exhausts?
3.) What fans (80/120) would you recommend (non LED)?
4.) I also want to get my HDD out of the way of the intakes. I have 2 HDD. I was thinking about putting them up in the 5.25" . . . But will that case them to get hot, as their not near a fan? Do they really block the airflow that much sitting where they were meant to be? Right not I have them in a vertical position, in front of the fans.
Any help is greatly appreciated. You can see system specs in my sig, if needed.
Take care.
Take care.
