So, with the proper case fans and power supply, how quiet do you think this case can be? Also, if you own this case I am interested in how you found it overall in addition to the noise level.
The 80mm fans will be a little noisier than say,a PC-7B with it's dual 120mm fans. Some people complain of the Lian-Li's having vibration noise, specifically from the side panels. I have had slight noise with my PC-7B but it's sitting on carpet which may play a factor in creating or reducing the noise.
I had two PC-60's for several years and they were very nice, but again, they were a little noisy from the fans.
