Lian Li PC-61 + CPU cooler
Miker2k
Looking to add a new CPU fan to my 555 BE but am concerned with clearance on the PC-61. It's got an 80mm fan on the back and will not fit anything larger which makes me think it'll be a no go on something like a 212+. Any suggestions for a cooler that's a bit shorter? I know that the case needs to be swapped out but the rest of the upgrade has been stealth and a case change might alert the keeper of my budget.
Noctua NH-U9B SE2 92mm SSO CPU Cooler
good cooler that may give you the clearance your looking for. also they have an 120mm that faces down towards the MB for slim cases. Only drawback is they are more expensive.
