I jsut got this in, and have started layout mods for it.
I Have a p4p800-e Deluxe, 1 DVD -/+ RW, DVD Rom/CDRW, 2 ide HD's, P4 3.0e
As to cards I am going to install I havent decided yet on that but its looking like I am going to transplant my SB Live w/ Digital IO card, and no idea on video acrds yet.
First thing first is cables, I hate them. I am playing around with using Cat5 Cable and jacks to make the removal of the MB tray easier for all the front pannel wires.
The On/Off, reset, HHD LED, Power LED would be 1 run of Cat 5
The USB header / Cable would be another and the firewird would be another (maybe)
Question I have is this - How would doing effect the reliablity of the ports ?
Now to the firewaire, is thier anything special that would need to be done to the cable so that it will maintain its high transfer rates ?
Next - how much voltage/amps can cat 5 cables take ?
So far I have cut off the fan guards, installed some UV reactive Fans, Heat shrinked the cables, and run them to thier hiding spot behind the MB tray.
Started tweaking the Power Supply lines, heat shrink and running patch to hide them, I need to find a better way to pop out the wires from the molex connectors..
Are there any low profile or 90* adapters that could be used for the usb connector on the MB ? the Cable as it stands has to just lay across the board as it too tall to make it turn and hide to the side, you wouldnt be able to plug in a pci card. I was thinking about using the individual plug ends and bend the MB connectors down and away to get the connector closer to the mb itself and then run it to the edge.
Just some thoughts so far.
-Robert
-Robert
