lian li pc-101 side window question
osirus35
I want to order the pc-101 but i cant seem to find a place that sells one with a side window. Do you guys think the side windows designed for the v1000 will fit on the the pc-101?
i dont think it will, but you can do it yourself!!! it makes for a very satisfying case when you make a major change like a side window by yourself.
i know there are window kits out there that you can buy to create your own side window but what do you suggest i use to cut into the side panel?
