Lian Li LCD
adamvk
Does any know of a manufacturer that makes an LCD Monitor that has the similar material that Lian Li has on their cases? (The brushed metal type material) If anyone knows of a manufacturer, let me know. Thanks!
Dell 2707WFP silver
Dell 3008WFP black
Somebody asked the same question the other day with respect to a Mac Book Pro.
Hope that helps
Dave
I don't want 27" because that's just too big, because when you play games at high resolutions, they get very slow.
Well the higher the resolution, the lower the framerates. Any gamer knows that bigger lcd means worse performance.
Well, even on larger screen you can play on lower resolution, saving the full for work etc. But never the less I respect your choice :)
The higher the resolution, the lower the framerates goes without saying. Though any gamer with a good video card doesn't worry about LCD size/resolution if their card has the balls to handle what they're throwing at it. ;)
there is a thread in this forum that is of really nice looking LCD in brushed alum.. its only avail in UK atm, i froget what it was called.. someone help me out?
Also, any human in the computer world knows that Lian Lis are made of aluminum, not some mystical "brushed metal type material."
Any worth in suggesting modding a monitor you like with an aluminum trim panel?
Probably Hazro you're thinking of. I emailed them and they said they hope to have a channel here in the US by fall, so we may be able to get one then.
27" too big? you may regret thinking that way.
I have a 37" westy, and it owns. just my 2 cents.
