QuadDragon
- Jun 26, 2007
Hey Guys, I am building a new I7 Rig and I do quite a bit of lan gaming. I was seraching the net and came across a really neat case mod to add a recessed handle to a case. You can find the link here. I wanted a case that had a solid top and front mounted USB ports, although I would have preferred them to be lower down on the case. Case weight was an issue, but to be honest after many hours of research I can't find an aluminum case that weighs that much less and has all the specs this one does. I will be putting my TRUE back on my i7 as soon as I get the mounts so room is also a factor. I found the LIAN LI Lancool PC-K56W. I would welcome any suggestions anyone might have.
