Lian-Li I/O Alignment Problems
FusionXP
I've been reading that some are having problems with the I/O shield and their mobos not aligning properly. Is this a growing issue with Lian-Li? I'm getting the new V1000Z but it seems this has that problem too (see newegg reviews and links below).
Overclockers UK
Post 79 of the same forum.
Its not a huge problem. Anyone who cant fit their io bezel in just isnt trying. Be prepared to do a little bending and a little banging, but it should eventually go in, without any aesthetic loss.
It's true.
I have a DFI JR 790GX and Lian Li A05 and I can't use the I/O shield because the mobo doesn't align properly inside the case. I am using without the shield.
