Lian Li EX-50 Thoughts before I bite
bencho
Hey all,
Does anyone have any comments on the EX-50 before I bite? It appears to be a great solution. Multibay case+PM for less $205. Other arrays like this would easily cost $500.
What kind of speed does the pci-x1 have? Is it 250mb/s ?
On newegg, it even looks like it comes with the little pci bracket card for pci-x1 so I wouldn't have to buy one of those.
If you've already purchased this or one of the other ones in this series, please chime in! Otherwise I'm going to bite this weekend.
Link for your convenience!
http://www.newegg.com/Product/Product.aspx?Item=N82E16816134001&Tpk=lian li ex50
It'll be software based raid so your CPU load will be high while accessing it, and compatibility with e-sata cards other than those based on the same chip (SIL5744) in the included card is low enough that you shouldn't expect to ever get it working with anything else. Other than that, haven't heard anything about these.
Damn... I knew it was too good to be true Sigh... i need something now tho :\
Actually,where are you getting this SIL 5744?
It says it uses SIL3132 on the included host card, which I believe is one of the newer chips right?
Does it work with onboard esata via jmicron chip? Or with 2port Highpoint esata card?
Are there any other 5 bay solutions that are in this price range?
Should I be looking at addonics and icy dock stuff?
