Lian Li Drive Enclosure Help
Carlosinfl
Loves the juice
I have the new'ish Lian Li PC-9F ATC case however I need to mount my 3.5" internal drives in the 5.25" drive slots. I found this but I don't know if it works in this case. Is there a way to find out? Lian Li is very hard to get in touch with and it just tells me it works with 'most' cases.
Here is the link to my case. Anyone know if the Newegg item will work inside my case?
Yes I will need to get some vented drive bay covers from my side of the Atlantic but for now I can disable to the 120mm fan.
Thanks for the recommendation!
