Lian Li Customize Store needed
lemmy
Anyone know a store which allows you to customize your lian li case like with fans or windows?
a hardware store :p . seriously man it's not that hard if you have the tools. Where abouts do you live? there may be some fellow [H] members that live near you and could give you a hand
If you're looking for the non-[H] way out and want to just but a pre-modded Lian-Li (now why anyone would want to do that I don't know), check out:
Wahoo Computers VERY expensive!
Performance PCs Look under cases, Pre-modded Lian-Li.
Voyeur Mods Some REALLY pretty mods here.
Unless you drop the major bones to have them custom mod it for you though everyone will be able to tell you tool the easy way out and just bought pre-modded. I'm of a mind that even if there's a couple boo-boos on a case you did yourself it's still better looking than having someone mod it for you though.
Plus, then you're really getting away from the cookie-cutter case. If you buy a stock, pre-mod there's dozens of other people with exactly the same "modded" case.
