Lian LI posted product info for the new Cube style case.
http://www.lian-li.com/Product/Chassis/Mini_PC-V300.htm
Steeeeve said:It is still going to have the same problems as the SG01 or Qpack...some heatsinks won't fit. Good placement of the hard drives. Cooling also might be an issue but it seems more SFFs are going back to 80mm rather than the 1x120mm
Also, is the side 80mm a slim fan? It seems to be cutting it close to the mobo. The photos can be seen here
http://www.sffclub.com/joomla/index.php?option=com_content&task=view&id=59
Lolento said:steeeve, do you know if the external 3.5" tray will get in the way of full length graphics cards?
Yeah, you are kinda limited...we will see though.ToastMaster said:fyi - the Lian Li has 3.4 cm in more heigh that, when it comes to heatsinks and fans, make a rather large difference (many heatsinks were just barely unable to fit in the Sugo). Granted, your massive ones probably still won't, but those aren't truly feasible anyway.
Danly said:I thought the cdrom would be mounted vertically in the front of the case. That would have been cool.
Danly said:When I first saw those pictures, I thought the cdrom would be mounted vertically in the front of the case. That would have been cool.
Reminds me of back when Mac made the iCube.ND40oz said:Slot load dvd that comes out the top, that would be pretty cool too.
VoBoy said:Reminds me of back when Mac made the iCube.
Myrandex said:Yea it is if someone goes to the site, clicks on cases, then micro cases. I am a member so thats fine with me, but still there aren't many points of login on the site. Hope that helps u fix it,
Jason
I tried, you can't do itMyrandex said:I think I did that as well. At least I am pretty sure I did.
Jason
synaps3 said:eww... that is just... nasty...
First the fishtank, then the snail, now thisSometimes I wonder about Lian Li
