Lian Li Case
I don't know anything about Lian Li cases, but i'm sure for those who do, that they'll need some more info about what model your case is in order to help you out. Give more deatailed questions if you want good answers ;) You also might want to mention in what part of the case you plan on installing the radiator.
I should have frased my question better, I need to know if any lian li case will support a dtek pro radiator core with a 120mm fan.
Maybe you should be more specific about that Lian-Li case
you plan on using with you WC setup.
With that being said
PC60 is a tight Fit both Vertical and Horizontally
PC70 is huge you can use a Dual 80mm or 120mm
or a single almost anywhere on that case.
