Lian-Li case Wire Management
Suprnova04
I've got a new Lian-Li PC-60. This is my first case build, and my plans are to make it look really tidy and do a lot of wire work.
I was thinking that I would be running a lot of the wiring behind the mobo tray, but not that I have the case I don't see how to get them there from the PSU. I figured that there would be a gap between the tray and the rest of the case, and the wires could go over the top of the tray and come out the other side where they won't be seen.
I know there is a way to do it, anyone have any hints/suggestions??
here are some pics of the area where I thought there was going to be a gap.
From the inside of the Case:
From the Outside of the case
1st off is you got a lian-li pc 60 you shouldnt even worry about wires cos you have no window.....and if you conserned get a dremel and start hacking away.
see mine
I'm going to cut my own window.
Can you possibly take a pic looking up toward the PSU so i can have an idea in mind when i start mine?
Yours looks very nice, btw
this is w/o side on
the wire hole
from the inside
thanks image shack for hosting!
EDIT these are more upto date than the 1st ones i posted
Ok, so i'm going to cut a hole like that then. Thanks a bunch for posting pics. Appreciate it a lot!
Yea, 1st rule of [H] wire management. If you need a hole, and there isn't one near by... make one!
the space or gap behind the mobo tray, does it vary from differnt models of lian li or are they all the same? im looking at the pc7plus or the pc65 plus
incomudro, I really like the sleeving on that 12v? wire right before it gets to the hole you cut (last pic). I would have just used electrical tape for that short of a section, but you get a A+ for over achieving.
acctaully that was my lazyness in not wanting to take the rest of it off lol
