LIAN LI Case Questions
s4rge
Lian-Li Classic Series PC-A05B
So i can get this baby for $80 from two sites so far.
My questions:
1. Where can i buy a side door with a window or window/fan (i will not do any custom mods windows to this case)
2. Can this case be setup for good cooling since its so small and doesn't have many options for fans. (8800GTX and overclocked quad heat monsters aboard)
3. Can you recommend a very quiet 120mm (non LED) for my powersupply. I recently changed my PSU fan with a new 120mm from bestbuy for cheap because the old one went out. Now i want a 100% slient 120mm fan.
Well, i like this case because its so small like many others.
Thanks
edit: This guy has a side window that looks nice- http://www.newegg.com/Product/ShowV...Size=6282388&title=VIDEO REVIEW: Lian Li A05B
I'm thinking about picking up the same case. There's a 138 page thread dedicated to this case already; it can be found here:
http://www.hardforum.com/showthread.php?t=1133290
As for a "100% silent 120mm fan" - I'm not sure such a thing exists???
:cool: Ok i exaggerated that, but i mean almost 96% slient. Where i can't hear the computer running. Right now i can hear my computer and its the PSU fan that i hear.
Anyone have ANY idea how the two blue fans are mounted by the GPU
Was this pic from the A05 thread? If so, you might have better luck PMing the user that posted the pic. From that angle its hard to tell, but I'm pretty sure its not one of the Lian Li accessories.
Ok, i found the answer to a couple questions.
1. I can order this case with a window for $159 than add my own rubber molding around the window.
2. Yes, but modding the case is the perfect soultion for better cooling.
So far. Im going to order the case with the window for $159 and the blowhole added for $19
Also, yes that picture is from that huge thread. Great thread
