Lian-li case question
Even if it is rivited in theres a million ways to remove rivits. Rivits are not all that sturdy, you can take a hack saw to them from the side, drill a hole through the middle, break the top of with pliers. I guarantee you will find a way of getting it off.
Seriously if you like the case buy it and if it isn't rivited fine but even if it is just remove them.
