i have a question about the lian li 6077 and 7077 series cases...
the 6077 and 7077 both come with the ex-23 hdd cooler/rack...BUT
the 7077 says it holds 4 hard drives
the 6077 says it holds 3 hard drives
if you buy the 3x-23 by itself it says it holds 3 hard drives
so the question is...does it hold 3...or does it hold 4?
on a side note the 7077 picture on newegg has the psu hole at the bottom of the top part of the back of the case...but a picture i found on some other site (not sure which) has it on the top of the top part of the back of the case, underneath the 120mm fan...is it removable?
