Lian Li case fans?
Cook_1
Anyone know what fans they use?
Or more specifically the noise and air flow output?
They're made by Adda. If mine were currently accessible, I'd pull 'em out and check the model number and try to look up the specs.
But they're reasonable fans. They're not the worst, anyway. I recommend replacing them. As soon as I got my case, I replaced them with some Enermax fans, which were quiet and had decent airflow. Now I have Cooler Master blue TLF-R82's in there.
Yeah, I have my PC OC'd and it's winter so the room temps are lower then summer temps, was looking into getting some with more air flow but wanted to stay on the quiet side.
Was thinking about getting these for my two intake...
http://www.frozencpu.com/fan-06.html
Getting four of these...
http://www.frozencpu.com/fss-01.html
Two more Q's (thanks for the first reply btw)
1. Are those two intake fans better then what Lian Li provides? Was trying to find something that has a decent dba to cfm ratio.
2. What would you rec for exhaust fans?
