PoweredBySoy
- Nov 14, 2005
I purchased a Lian Li PC-60FB from Frozencpu with the intent on adding in a 120mm side fan. When I received the case I was a bit disappointed to find out that the side panel had factory perforated holes in the lower left - as all pictures I've seen of this case did not show. I dremeled my fan hole in there anyways and tried my best to cover the perforation. Well - it worked, but it kind of looks like shit.
So - I'm looking to replace the side panel, one without perforation, and start over. I found a panel which I think would fit, but I was just wondering if anyone could confirm it's the correct one, and if I do order it that it's not going to come with a bunch of holes in it. Is there a better place to buy from than Performance PC?
Thanks, amigos.
Thanks, amigos.
