Lian Li Assembly Screws
P4rD0nM3
Anyone here if Lian Li will ship out replacement assembly screws for the whole case?
I can't seem to find my screws so I'm just looking to buy the whole kit if ever so I can assemble it back.
I already sent them an e-mail.
i think they are just m3 threads but i think silver pc or performance pcs has them
I'm talking about the really small anodized ones...I don't think it's available online like the other screws.
Ya know, I've considered, for a long time, drilling out the rivets on my case and buying countersunk copper hex bolts and matching nuts, and then reassembling it. Alternately, if your aluminum is thick enough, you could tap all the drilled holes and use just black or copper countersunk hex bolts and it'd look pretty badass, and you could disassemble and reassemble at will.
No no no...I'm talking about the really really small screws that you need to assemble the brushed aluminum parts. I have no problems riveting them back, I just need the screws for the ones that can't be riveted.
