I grossly underestimated the size of this full tower Lian Li PC-A77B for my new build but I'm overall pretty happy that it can easily accommodate many triple radiators in this thing. Problem is, this fan controller thing that Lian-Li included on this case. Its not really useful, sure you can connect to 3 fans to it but you cannot manually control the speed of each fan, it will auto spin up if it is hot enough.
Weird thing about it is there's 3 connectors CPU fan, SYS1 fan, SYS2 fan. Then in the instructions it specifically says "Do not connect CPU fan to the controller", then whats the point of having a connector with the CPU label and the LCD saying CPU fan?
I tried to replace this included fan controller but it seems it is not a standard 5.25" or a 3.5" bay controller. Anyone have this case and replaced the controller with something else?
Other than the weird fan controller this case has pretty much surpassed my expectations and will be home to my new i7 build in the next couple weeks.
