Lian Li 343 Radiator Brackets
Are these brackets exclusively only for Lian Li or can they be mounted on other cases such as antec? Also will they work with the swiftech MCR220?
Thanks,
Mark
I am sure can be fit on other cases(I don't see why not). The brackets will hold a radiator of any size, as long as you have the space in your case.
