LHS Coupo, 50% off
Decker87
A local hardware store has a 50% off coupon for today only in the paper. It's called TrueValue, I don't know how many other stores there are or if they have the same coupon. What should I get?
I get 50% off one item $50 or less. What should I get?
I always use things like that to get a discount on a set of tools. - Buy yourself a new 1/2" drill set or something. The question will be more easily answered by knowing what you NEED.
Or... Buy a dremel
qbackin said:
Dammit I want a dremel. Whats a good one to buy?
It depends what you want it for. Do you do any woodworking? Crafts? I got the cheapest dremel, a corded 1-speeder but I regret it now. The first decision is corded or cordless? Corded ones have more power, but you don't always need more power.
Probably the best overall kit is this: http://www.dremel.com/productdisplay/tool_kit_template.asp?SKU=3962-02&Color=99CCFF
Variable speed, 5 year warranty, tons of bits included, and a storage case. Trust me, you will want a storage case!
