lga775 HSF recommendation
Ranulfo
Need a possible recommendation for a replacement HSF for my q8400. Its been runnin rather hot lately when gaming with a new video card. Looking for something not too loud but will keep the cpu under 70C. Stock HSF is running up to 80-83C when gaming (usually in the 60s with older video card).
TIA
I agree entirety. Not really worth spending more on a 775
I would not recommend that for an lga775 processor at this time (especially for a dual core), well unless you can get it used because the HS would cost more than the CPU is worth..
Why does it matter? The H50 can be used with newer CPUs as well....
