teh RedUnit
- Mar 22, 2005
First off, here are my PC specs:
Intel P4 550 3.4GHz
Asus P5GDC-Deluxe Mobo
Asus EAX600TX/TD Video Card
1x 120mm intake fan, 1x 120mm exhaust fan
WD 36GB Raptor SATA Boot Drive
WD 250GB SATA Storage Drive
Coolmax CR-450B 450W PSU
Zalman CNPS7000B-Cu HSF w/ LGA775 adapter clip
Okay, I just upgraded my PC from a 2.4C P4 which I had running at a cool 29 degrees idle with the same HSF and case fans. I decided to buy the LGA775 adapter clip for my Zalman HSF because the HSF did a great job at cooling my old Northwood.
On this 550 CPU, my idle temps are around 55 degrees and have gone as high as 79 degrees while installing Photoshop and other applications. My mobo temperatures however, stay at around 33 degrees. I used Artic Silver 5 and got those temperatures. I also have the Zalman HSF running at full blast (2500 RPM), PSU at full blast, both case fans running at ~1600 RPM. Both BIOS and Asus PC Probe give pretty much the same temps, so I'm guessing they are accurate.
Also, my CPU is running at only 2.8GHz (200MHz x 14) and I don't know why. I can't immagine the temps if it was running at a full 3.4GHz. Is this the Mobo underclocking the CPU because of high temps?
Here's what I've done so far:
I removed the HSF and re-applied the AS5 but still kept temps high. I've been reading other people's problems but I haven't found anyone with the same mobo and cpu combo as I do. I am tempted to remove the Zalman HSF and use the stock HSF, which I am doubting will do a better job. I've also ran the comp with and without the side panel but still get the same results.
I've already read Intel's temperature recommendations for the Prescott, and while at idle, it's somewhat whitin range, 79 degrees at load is way too high and I am concerned. The underclocking is still a mystery to me and I don't want to try and raise it because of fear of higher temps.
Any help would be greatly appreciated. Thanks
Intel P4 550 3.4GHz
