Finally, here are some solid specs for socket 2011.
http://www.techpowerup.com/143179/Intel-X79-Enthusiast-Chipset-Sketched-in-Roadmap.html
yum quad channel DDR3...
That's flawed logic. When this ships ... the next one is right around the corner, so you might have to wait a bit.Hmmm....
I was about to buy a new i7, but after reading this I might have to wait.
When you compare x79 to p67, there's not much difference other than a new CPU socket and quad DDR channels (which isn't going to make a difference in performance outside of benchmarks). It doesn't even have native USB 3.0.
Perhaps that (lack of USB3) has something to do with Light Peak.
http://www.intel.com/technology/io/thunderbolt/index.htm
Thats with intel chipsets. Who buys intel mobos?
The one thing I want is for them to actually make these more workstation-minded (if that's a word) for the average consumer
The i52500K was introduced, and it's powerful. Introducing another CPU which is essentially the same but just another version of this CPU and there is probably no reason to go the other route.
My wishlist for Intel is that I would like to build a dual CPU 2011 8-core 16-thread system with room to grow in the future (12 cores, 16 cores etc), 8 ram slots for 64GB+ and all of that on an ATX or SSI-CEB form-factor motherboard. The Tyan S7025 should be normal for consumers, and not that much more expensive than the "mainstream" p67/H67 boards. Minimize the PCI-e slots if needed (I need just 4~5, depending on what else the board has), and ditch the PCI slots entirely.
Not E-ATX since that makes it too large; ATX or SSI-CEB can work fine and dandy.
The Mac Pro can, it's time to give us on the PC side the options to build such a machine as well.
That's my point. IMO, Xeon's shouldn't really exist. A P67 system nowadays is fast enough, that to just add more bells and whistles to an X79 just makes it a souped up P67, not an entirely different breed of CPU like it should be.
Extra lanes? Whohoo. More Satas? Whoop-dee-doo. The total amount of ram remains the same, the CPU frequency are negligible, I see no reason why you woul go for an enthusiast over the current mainstream.
Unless, the X79 is much more beastly than the P67, which IMO can be achieved by literally doubling the total ram capacity, the possibility of dropping in a second chip for more processing power, etc. We've had dual CPUs in the Pentium 3 days, why can't we have them back now?
For me, that would be a key selling point. Not extra PCI-e lanes or 4 more sata ports (which I can get with an add-in card anyway), but an extra CPU socket and more total RAM without needing an E-ATX board or fully buffered DIMMs.
IMHO.
IMHO.
What happened to PCI Express 3.0 ???
Why aren't people talking about that? That was the real motivation to wait for X79 in the first place. All info (up to now) was pointing to "PCI-E 3.0 being debuted with LGA2011", and now that's gone.
Generally speaking, my "full system upgrades" only happen when there is a jump in physical connections like PCI-E 1.0 to 2.0 (otherwise I just stretch a system's lifespan by upgrading it as far as I can with newer CPUs and GPUs, adding more and more RAM and extra HDDs, and now SSDs). PCI-E 3.0 would be a worthy upgrade path because all new high end video cards would use the new spec. Only problem is that it's not happening....
Not true.No more QPI either.
Not true.
Do you see QPI mentioned anywhere? Because all I saw was a DMI link to the southbridge, supplemented with the x4 PCIe. But I guess it doesn't really matter, since all the PCIe lanes are off the CPU anyway.
Server chips exist so that Intel can sell you 24/7/365 uptime and reliability. ECC/Registered RAM goes hand in hand with that. As do the features on a typical server-class motherboard, which are generally along the lines of "remote-monitoring/access/change/security"-type deals. The margin on server chips is HUGE and that's why Xeons do exist. Most server features are wasted on the general public.
Your suggestions are eerily reminiscent of Intel's "Skulltrail" platform, which utilized a 2-CPU socket, FB-DIMM EATX motherboard and support for Xeon 2P CPUs. It was ludicrously expensive for its time, didn't perform that much better than a similarly configured Core 2 Quad system in most general tasks, and ended up being an abject failure. The closest thing I can think of that exists today is the EVGA SR-2, which, due to its cost, also isn't exactly flying off the shelves.
You suggest eliminating the need for EATX and registered/buffered DIMMs, but if you're going to load up on multiple CPU sockets (with the attendant HUGE CPU coolers that we have today) and 128 GB worth of memory populating 8 DIMM slots, you pretty much have to have EATX and better memory. People that have these outsized requirements are going to buy true workstation/server class hardware.
LGA2011 just sounds like a classic upsell - you'll probably get like 5-8% aggregate performance boost over a similar P67 platform, but at like 20-30% of the cost. For most people, that's surely not worth it. But here on [H], it just might be. We'll just have to wait and see.
QPI never mattered for single CPU setups. Its for SMP systems. Its a direct link between the chips. The Xeons are going to have 2 QPI links. Just because stuff isn't mentioned in very early leaks doesn't mean that it isn't going to happen. Those slides are far from the full feature list of the chipset.
Is there an expected release date for all this? Been trying to find one, cant seem to find anything.![]()
