LG L246WP / L245WP
Elokan
I can buy these two for the same price, but I can't find ANY difference between them. Is there one?
Also, what's the L246WH? Is it better or worse?
How do these compare to the 22' (L226WA) in terms of input lag and overall picture quality?
Thanks.
according to some other threads, they're the same panel, just sold through different places
L246WP is retail version, L245WP is reseller model, with a different power button. Other than that, they are exactly the same.
I see. I guess they are identical.
What about the 3rd one?
Did anyone manage to check input speeds? Do they perform well in games?
Hello from Germany,
the L246WH is definetly a TN-Panel. I could compare the LG 245WP with the LG 226WTQ and - although it was a surprise - the colors were equal, absolutely. With the f-engine switched-on at the 226WTQ the picture quality bursts the 245WP away.
I decided to buy the new 246WH because the quality of the picture was not a bit worse than the 245WP. Besides, the 245 and the 246WP are absolutely equal, there are only different numbers because of the shipment to europe (245) and other markets.
Regards.
LG L246WH 400cd/q 2000:1 8ms H Wide DVI-I sw
Gehäusefarbe: schwarz
Diagonale in Zoll: 24 Zoll
Farben: 16,7 Mio.
Betrachtungswinkel horizontal (typisch * in Grad): 170
Betrachtungswinkel vertikal (typisch * in Grad): 170
Helligkeit (typisch * in cd/qm): 400
Response Time (ms): 8 ms (Grau zu grau)
Kontrastverhältnis (typisch): 2000:1
Horizontalfrequenz (kHz): 30 - 83
Vertikalfrequenz (Hz): 56 - 75
Videobandbreite (MHz): 135
Max. Auflösung: 1920 x 1200 @ 60 Hz digital
Eingangssignal: HDMI (mit HDCP), Komponente (YPbPr), 15 pol. D-SUB Lautsprecher (integriert): k.a.
Neigungswinkel: 25° nach oben, 5° nach unten, horizontal 350°
TCO: 99
Abmessungen (mm): 560 mm x 444,5 mm x 270,2 mm
Gewicht: 9,6 kg
Besonderheiten: HDMI mit HDCP, PIP (Bild in Bild), Komponenteneingang, Int. Netzteil, Kensington Lock, OSD Sperre, höhenverstellbarer Dreh- und Neigefuß
