LG L246wp has problems turning on.....
user3657
Ive had this monitor for 4-5 years. Recently the past 2 weeks when I go to turn it on it can take 40pushes of the power for it to finally turn on. It does not happen if its been on for a while and I turn it off, then turn it back on. Its getting worst too, when it first started to happen 2-3 pushes of the power butten turned it on. Its not just the power switch, once it finally turns on, it reboots 2 or 3 times at the start before finally turning on. Once its on, it runs as normal with great color.
Anyone have any idea? Should I take it some where? Or would it be cheaper to get a new monitor? Any ideas on how to live with it? The computer is in my room so I turn it off at night but for the most part the monitor stays on all the time even if I run out for a little bit.
