LG L227WTG resolutions
Yams
I have an LG L227WTG hooked up to my laptop through VGA. The native 16:10 1680x1050 resolution looks great, but with some games I need to run the monitor outside of its native resolution which leads me to this question/problem. I'd rather keep within the 16:10 aspect ratio, but certain resolutions just don't work. 1440x900 works fine, but 1280x768 switches to 1024x768. No matter if I change the resolution in-game or on the desktop it will always go to 1024x768 when selected. The 16:9 resolution of 1280x720 works fine, but the image in-game appears a bit weird. I would like to utilize these other 16:10 resolution besides the native, but I just don't know what's up.
Does it have to do with using VGA? I can only connect via VGA to my laptop. Would using a DVI to VGA adapter work? Any help would be appreciated. Thanks!
Can you have it set at 1280 x 800? This is a 16:10 aspect ratio. 1280 x 768 is not.
So what are 16:10 resolutions?
I tried 1280x800 in-game and on the desktop. The weird thing is that at 60Hz the image goes to 800x600, but at 75Hz the image goes to 1024x768.
From what I've found 4:3 resolutions work fine, but every 16:10 except native and 1440x900 will revert back to a 4:3 resolution.
What game is this anyways? As far as 16:10 resolutions
1152 x 720
1280 x 800
1440 x 900
1680 x 1050
Try 1152 x 720.
It's in any game.
1152x720 goes to 1280x720
I've even tried three different drivers. No change.
Just tried two more drivers, same exact thing. Except for 1680x1050 and 1440x900, the other 16:10 resolutions will switch to lower 4:3 resolutions (either 1024x768 or 800x600) in-game and on the desktop.
The only thing I can think of is that maybe this monitor can't display those resolutions or at least maybe not over VGA. Any thoughts?
Why do you have it hooked up VGA instead of DVI? I tried doing 1280 x 800 with Crysis Warhead on my 22" HP and it will display it fine. I have this hooked up via DVI on the video card to HDMI on the monitor. Hmm.. I wonder if it's just your video card. I almost was gonna buy that LG 227WTG-PF monitor instead of my HP. If I did, I would have been able to answer your problem better cause then I would have the same exact monitor as you.
Damn, no wonder why you have to drop the res in gaming. I was thinking earlier: "He must have a pretty weak GPU"
It's an 8600 GT equivalent. I can run all Source games on high at the native res, it's just that Left 4 Dead struggles a little bit at that resolution and I'd like to bump it down below 1440x900 to increase the fps.
i have a L227WTG-PF on Vga and (6600gt) It can display all the above resolutions. (includeing the ones you have a problem with) It has to be your laptop. Are a driver issue. Can you tell me your chipset revision
I CAN TELL YOU THAT THIS DISPLAYS ALL 16:10 AND 16:9 RESOLUTIONS FINE AND ALSO HAS 1:1 PIXEL MAPPING ON ALL RESOLUTIONS
Where do I find the chipset revision?
I thought you couldn't do 1:1 pixel mapping over VGA.
yes you can have 1:1 pixel mapping on over vga. it just that during the anaolg signal it calculates which pixel is supposed to be what color at a certain time whereas dvi tell each pixel. I have ran a number of programs at diffrent resolutions its your laptop just to make things simple
