LG L226WTQ-Bf Ghosting Issue
So I bought this from Best Buy a couple months back and it didn't seem to have any ghosting issues. The past few weeks though I am noticing it reallllyyy bad in games. It is noticeable on my mouse as well if you move it on a grey background or other colors in that ballpark.
Is there anything that might have been fouled up to start this? I mean hell....it has a 2ms response so I thought that would be more than adequate :confused:
Try disabling the overdrive function for the monitor (it will now work at 5ms instead of 2ms) and see whether the problem is solved or not.
Well, about that you have to consult the manual. I do not have this monitor after all.
