LF fan controller/hub 5.25 recommendation
Ranulfo
Any recommendations on a 5.25 fan hub? LCD is ok, not looking for anything too fancy, but something that I can manually control 4 case fans with from a front bay. Current controller is a built in switch on the case that appears to be dying and only runs at high.
I always recommend the NZXT sentry 3, it have a nice touch screen and temperature sensors so you can adjust your fans RPM based on those sensors, which its good to monitor intake/exhaust air temperature inside the case..
