PCMusicGuy
- Feb 9, 2006
I just want to bounce some ideas off the members here to see if I'm missing any options.
Current Setup: I have the creative home theater cable that takes the three analog jacks and breaks them out into the 7.1 analog channels, so I use the Left/Right and Subwoofer analog outputs of an X-Fi configured in 5.1 mode, with bass redirect enabled and rear speakers disabled. The Left and Right channels go to an amp which is connected to the speakers and the subwoofer output goes directly to the LFE input on my sub crossed at 80 Hz. It all works perfectly.
Desired Setup: I want to bring the amp, speakers, and sub to my office and use a laptop as the source. Naturally, since my laptop only has a headphone output, I don't have a dedicated sub output. My sub does not have pass through ports, and my amp does not have a separate sub output. The laptop is a Dell Latitude E6510 so no digital outputs available, other then possible
Options: I can only think of 2.
1. Get a receiver and use that for the speakers and sub, then connect the laptop to the receiver via a 3.5mm to L/R RCA cables or displayport to HDMI (assuming my displayport will pass audio and the IDT drivers aren't too crappy). Not crazy about this as I'll have to spend some money >$300 to get the same output and quality my current amp provides.
2. Get a USB 5.1 audio card (something like a Creative X-Fi Surround 5.1 Pro USB) and hook it up similarly to what I have at home. I'm leaning this way since it is only around $60.
Anything I missed?
Anything I missed?
