Let's talk about Screws
vjcsmoke
So I want to mount my 360 rad at the top of my HAF932 case, but I don't know what type of screws or how many I need to do so. Can anybody who has experience with this mounting fill me in on what I'll need to buy?
I just went to the hardware store and picked up a bunch of 6-32 1 and 1/4" screws + bolts to mount my fans. But I still need screws to mount the 3x120mm radiator into my case. Appreciate the input.
I think you use the same type of screw as you have listed right?
It does look like those may work. But I just ran into another problem. The 230mm chimney fan that I need to take out is secured with some weird hex nuts. What size hex tool do i need to remove them? Grrr. Stupid nonstandard screws! What ever happened to 4 head phillips screws. Had to deal with some weird torx crap to open up my mcp355 pump.
