Let's have a power consumption fight.
MisterDNA
My Thinkpad R40 consumed 7.5W average with every major power save option enabled. I recently tuned it and I've got the following, according to the wattmeter in IBM's software, BatteryMon and some popular hardware control app I uninstalled (all three were within .06W of each other):
With display on, hard disk spinning, ORiNOCO enabled, typing in OpenOffice.org:
6.47W average with periodic spikes to 7.22 due to WiFi
Same with hard disk spindle stopped and WiFi radio off:
5.96W average, spikes only when hard disk starts back up.
I have yet to try the system with the Intel WiFi 11b card back in it. It takes less energy, but I don't remember how much less. With the mini-PCI slot empty, reading drops by almost exactly .5W.
With the display turned off, consumption drops by 1.5W. This isn't just the backlight shutting off, however. The display completely blanks, leading me to believe the GPU shuts down to some extent.
I haven't figured out the nature of power save on the Soundmax codec chip. I don't hear it switch and there's no option for it.
With everything completely stripped to the bare essentials (one RAM module removed, CF card out, external display, no WiFi card) and the hard disk off: 3.1W
Way to go, Intel.
Config:
P-M Banias 1.3GHz
2x512MB DDR PC2700 I think
80GB Toshiba MK8026GAX 5400RPM 16MB cache hard disk
Radeon 7500 32MB
15" XGA TFT
nothing in device bay (bay's faulty. Won't even recognize a drive now. Bummer).
Intel WiFi replaced with ORiNOCO 200mW output abg card (max powersave enabled)
Inverter pots backed all the way down
ATI PowerPlay enabled
CPU throttled back to 600MHz
no undervolting (wish I could without bloatware)
1GB CF card in PCMCIA adapter (used for OpenOffice storage)
ThinkLight off
impressive, seeing as my X40 = LV 1.5 dothan at a bottomed out voltage at 600mhz, wifi off, hdd spun down, and screen off, cant break under 6 or 7 watts.
average with everything on and screen at dimmist, 9-10, cpu dynamic and high brightness, 12-13.
but then, banias was better in the low end.
dunno about core 2 ibm's
curious though, inverter pots? are you referring to screen brightness?
Inverter pots as in the mechanical screen brightness. I don't know if that's what they actually control, but I figure it since inverters necessarily vary in output and have to be calibrated.
There are two small variable resistors on the top side of the inverter PCB in my R40. I Dropped those all the way down and the backlight stayed stable. Cranking them up all the way makes only about 1.5W difference, but the panel gets a lot brighter.
I had an SXGA+ panel in this system a while back that was taken from a broken Dell lappy. It took a lot more energy to run, but looked better in some respects. I never tried that on the lowest inverter pot setting. Maybe I'll have to do a little experiment.
I'm quite sure the SXGA+ panel that is meant to be in the R40 is a lot more efficient. The Dell I got the other from was one of those P4M beasts that doubles as a space heater.
With my Asus notebook in sig, i get around 11wts/hr with the screen 2 notches up from min, cpu locked @ 1ghz @ 0.95 volts, and disabled everything i'm not using (card reader/dvd drive/wired lan) still use wifi, not quite as low as you, very nice figures there.
thanks. I waited almost ten years to get a laptop that was as efficient as my old Toshiba T1850. I could type with that thing for almost the whole day on a NiCd pack that was five years old. I really wish I could use the R40 outside as easily as the T1850, though. I can get the sun to light the panel for me enough to type, but the matrix goes dead with the backlight.
I was really getting tired of lappys that try to torch my crotch. Fortunately there was no permanent damage. My daughter, due July 4, is proof of that. :D
