undertheradar
- Oct 26, 2004
Why decrease the efficiency with a water cooling loop?
Why not just remove the heat collector and replace it with a block mounted directly to the CPU? This is what phase-change systems do after all.
You are adding multiple layers of complexity as well as hazards to the design that diminish the end result and efficiency (a water pump adds all of its wattage as heat to the line).
