So it overclocks just like last batches of rx480s? What news are there to it?
yea my 480 only does about 1425 but honesty its in my backup rig and i havet really tried to push it.
I know of at least 2, so 0.01% of rx480s certainly do hit 1500. Consider that we're dealing with possibly cherry picked unit and not statistic on clock binning, after all, so anecdotal sample of 2 suffices for my point.You want to point me to percentage of rx 480 that overclock to 1500mhz guarantee?
We are dealing with literally 1 out of lord knows how many 580s as well.1 out of 100 doesn't really count.
You could most probably overclock this card a lot?
Clock speed maybe 1600 mhz ?
Memory speed maybe 2300 mhz ?
or am i dreaming?
I am sure living in cold areas must be awesome so overclocking must be easy?
how do you reckon the pricing will work?
cheaper or same as the RX4 series?
or am i dreaming?
You probably are.You could most probably overclock this card a lot?
or am i dreaming?
Never a given with AMD stuff after Ryzen debacle.Given that it should OC at least as high as boost
These are all 480s/580s bro.The low end RX 560 even beats a 1060 running at much higher clock! Jesus ouch. Does anyone have power draw numbers of a 1060 overclocked?
Your opinion on anything nV/AMD is almost as interesting to anyone as Shintai's on anything AMD/Intel-nV. So, go figure.So that 1500mhz card is the RX 580. Well so much for the 1060 then.
Am I the only one sitting back laughing at posts like this?
WHO CARES?! When was the last time anyone gave a shit about a 1060 and below? Forever, because it is old news and boring.
What makes it even funnier is that you have people dry humping a refresh of a 480 because its beating the second lowest card offering from Nvidia.. It doesn't matter. It is a pointless argument. When your highest offering is just beating the competitions second from the bottom offering, you're doing it wrong.
But i'll tell you who does care: nvidia
Anyways, what i find really funny is the gall AMD had to literally rebrand a GPU die itself.
Oh now now, don't encourage your inbred brother. Clearly you don't care about the 1060 but of course you are in the vast minority. But i'll tell you who does care: nvidia.![]()
I am in the vast minority? Of people that don't care about the 1060? I just want to make sure I am understanding you correctly, because this comment is loltastic.
You can't seriously be having trouble understanding that? I"m not even going to bother, figure it out on your own while you are loltasticing
This is the same as videocardz right
Really still will never understand why people believe anything WCCF publishes.
Remember they continually propped up the RX480 as being the second coming of Jesus. Nothing but bullshit from that site. lol
idk I saw this at wccftech, don't remember seeing it at videocardz. Reason I mentioned hype train in the title because it was from wccftech. This is more believable since we have been hearing about refresh will likely clock higher. May be AMD for once make overclockers a little happy.
Power color is going to have a rx 580 golden sample lol. I am wondering what that is all about, triple slot cooler and shit.. shit looks like its running at 2ghz. hahah.
https://videocardz.net/powercolor-radeon-rx-580-8gb-red-devil-golden-sample/
Yeah that's an awesome looking card IMO.
This exchange between zerocool and a Gigabyte rep on Reddit is verrry interesting. Considering that the RX 480 was the very first 14nm product from GloFo it isn't hard to imagine the clocks going up a fair bit for Polaris 20.
Again a respin won't do miracles for frequency, I think 1500 is max on these things.
I'd say a likely 15%+ reduction in power, although I'd expect gains on a GPU to exceed CPUs with their parallel nature and power draw patterns. Clocks likely closer to max as we've seen with Zen and limited overclocks as they naturally operate close to their theoretical peaks. Hardly a miracle, but fixing the sloppy process issue that was speculated on a while back. That's independent of other process improvements.TechReport said:Merritt goes on to comment on the techniques AMD has reportedly employed to reduce Zen's switching capacitance by 15% when compared to existing chips. Zen is apparently the first design where AMD used metal-insulator-metal (MIM) capacitors, a move that's said to allow reduced processor voltage and more fine-grained control over per-core frequency and voltage.
