grandpatzer
- Feb 24, 2010
So I'm using Kombustor to test out clocks.
Without touching volts when I run 1125/1375 gpu-z reports VDDC 1.051 (starts 1.057 then goes to 1.051)
Without touching volts when I run 925/1375 gpu-z reports VDDC 1.057.
This is 21% core overclock.
This give 19% more fps in Kombustor.
Question:
A bit weird that more speed needs less VDDC?
Edit--> I also now overclock memory so: 1125/1431 and not even 1fps increase, also the gpu-z shows 2900mhz memory clock
Question:
