Less than $1500 Rig.. Need your suggestions.
Betauser
Ok, it's almost time for me to get a decent rig in order for me to run some current gen games... Need your suggestions on these parts I chose from Newegg
NOTE: Might not get the CPU from Newegg since it's not guarantee G0 stepping.
what do you guys think?
CPU Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Mobo ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
Video Card EVGA 512-P3-N802-A1 GeForce 8800GT
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130303
HSF Thermalright Ultra-120 Extreme CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835109140
Memory G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model F2-8000CL5D-4GBPQ - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
PSU CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
HDD Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136011
Case (need help on this one) COOLER MASTER Ammo 533 RC-533-SWN1 Black/ Silver Aluminum+Plastic front bezel; SECC chassis ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119098
DVD Drive SAMSUNG 20X DVD±R DVD Burner Black PATA Model SH-S202G - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151151
PLEASE list the part names so we don't have to click on a dozen links. Thanks. ;)
Everything looks great. Though for personal preference I would look into the Crucial DDR2 800 kit of memory. As for the HSF you only listed HS and not the F. You have to buy the fan separately and your best choice will probably be a nice 120mm S-FLEX fan. For the case I think it's a nice case since it's the one I am currently using and I just love it especially for the handle when I go to LANs.
Thanks for the comments guys.. I edited and listed the parts name as some of you had suggested.
I'm thinking of the HS fan S-FLex anyways.. but i didnt see one in Newegg..
I like the CM RC-690 better, but cases are personal preference, mostly. Too bad the price went back up to $80. It was recently $60 - $20MIR with free shipping from zipzoomfly. Oh wow, zzf got a facelift... nice. I guess they gotta pay for that facelift, so they raised prices, lol.
Looks pretty good, but I would make a few changes. Firstly, the power supply is too high wattage, much more than you will need. A 520W would be plenty for SLI. Second, the graphics card, you might want to buy a better cooler for it. Up to you, though I would recommend it if you are going to overclock it. I would choose a better case, the Ammo is really for LAN only, and is only OK. A Silverstone, more expensive CM, or Lian Li will fit the bill nicely. Scrap the Raptor, a RAID0 Seagate 7200.11 setup will be much faster. Either way, get Seagate 7200.11 drives, they are pretty much the same in performance as the Raptors, and they cost much less.
One small detail, do NOT get the PATA version of the DVD drive, always go for SATA versions, smaller cables make for easier cablerouting and besides it's a never standard...
